closing a side dart on a torso
Mon, 07/27/2009 - 10:59
ettaglam
User offline. Last seen 16 years 42 weeks ago. Offline
That Is my question.  I know that if you close a dart at least 1/2 inch is added some place else but where.  I need to close a side dart in a torso design.  I found this site because Iwas trying to find out that answer.  I'm glad that I found esewing and look forward to using it quit often
ettaglam
Mon, 07/27/2009 - 11:12
Re: closing a side dart on a torso
Hi ettaglam,
Bellow you can find the most common ways to transfer a bust dart intake.
  1. If you close the side dart (Bust Dart), which is from the side seam to the bust point, you can transfer it's intake to the shoulder dart that goes from the shoulder to the bust point.
  2. You can also do this from the armhole to the bust point (here you draw a curve line from the armhole to the bust point, and then close the bust dart, you need to leave a seam allowance and trim the excess)
  3. Another way to transfer this intake is to draw a line on the pattern from the lower or upper hip or somewhere in between to the bust point. Then you draw the waist dart here on this diagonal line. After closing the bust dart, the waist dart and the bust dart will become one.
  4. You can also draw one or multiple lines from the neckline to the bust point, cut these lines, place a sheet of paper underneath, space them out equally, tape them in place, then close the bust dart. In this case you can sew different darts around the neckline or gather around the neckline.
There are many other ways to transfer a bust dart depending on the style of the garment. You can watch one example here: Styling the Front Dress Pattern
Hope this helps
Nehzat H.
