Triple threads
Fri, 07/06/2012 - 10:45
KT1408
Hi Nahzat,
What is the technique for hand sewing with triple threads? What kind of project would that be used for? Cushions? I think saw something on it on your site but can't seem to locate it now.
Thank you for the esewing site. I'm loving it and learning so much  I  now try to emulate your lovely careful way of stitching especially when doing hand sewing and it it's starting to look pretty good  - if I may say so myself! I have even used some of the different stitches to give the odd thing a bit of a lift. It's great fun. My next endeavour will be learning how to use a block pattern, although I'm not sure I'm quite at that level yet.
Kate
Tue, 07/10/2012 - 18:20
Re: Triple Threaded Needle
Dear Kate,
Thank you so much for the kind words. You can use a triple threaded needle in embroidery. Using more strands will make the embroidery stitches stand out.
You can also use two or more strands to sew on a button faster (using less stitches). However if your fabric is light weight it is better to use a double threaded needle to reduce the bulk, especially when securing the thread.
