Welcome!  New visitor? Join now, click here.  Already a Member? Sign-in here.
Questions? Call Free 1-888-889-7544 or Internationally +1-647-260-0615
  • Member Log In
  • Home
  • Online Learning ▼
    • Garment Sewing + Alteration
  • DVDs ▼
    • Garment Sewing + Alteration DVDs
    • Tell a Friend (Email Form)
  • Learn More
Where to add ease to block patterns
Wed, 08/17/2011 - 22:31
sewmama
User offline. Last seen 2 days 10 hours ago. Offline
   Please help me to understand where to add ease to a block pattern.  I also am wondering if there are any rules to follow.  I know the actual numbers can depend on individual preferences, but in the armhole at the different areas that you would add ease, these numbers would not be the same amount, for example, you would not add 0.5 cm to all the lines that affect the armhole, is there some rule as to how much these numbers would differ in the different areas of the armhole?   I ask this because I have seen an illustration in a library book where 0.5 cm is moved from the neck area and added to the shoulder line at the other end by the armhole, then a line they call the cross back line they added 1cm, (this line is in the middle of the armhole) then moved the armhole down 2.5cm and out 2 cm. This was on the back, for the front the numbers were the same except  the middle line which they call the cross front line was 0.75 cm instead of 1 cm.  Once you have the amount (whatever that is, according to this book the numbers I mentioned were the minimum amounts for wearing ease) how do you know how to change it to larger numbers, if you would like more ease?   Is there some rule about the numbers that I just mentioned, something about how far apart (their differences) they should maintain.
I'm sorry, I don't know if I've explained  what I mean clear enough.  I really appreciate your help.  Thank you, so very much.
Carol
Comments
Thu, 09/08/2011 - 16:54
User offline. Last seen 1 hour 59 min ago. Offline
Re: Wearing Ease
Dear Carol,
There are no set rules about adding wearing ease. As you mentioned it all depends on your own preferences.
That is why when ever you want to add any ease to a pattern you should always test it on muslin first.
Once you try on your muslin garment, you can make any extra adjustments by taking in or letting out wherever you want to.
Once you are satisfied with the fit you can transfer these changes to your pattern.
The instructions in the book regarding adding ease to the armhole sound good to me. This is needed if you are planning to sew sleeves to the armholes. Again make sure to test the fit on muslin.
Happy Sewing,
Fri, 09/09/2011 - 11:11
sewmama
wearing ease
Thank you, very much, Nehzat, your help with my questions is very much appreciated!
Sincerely,
Carol
Email or Share this page:
Quick Links
•  Add Your Photos
Watch on Your Mobile Device
  • Kurta
    rosie_vora
  • Re: Kurta without Zipper and Center Dart
  • Re: How to keep the shoulder in place on open necklines
  • Re: Neckline for Mid Season Fabric
  • Re: Bias tape Gathers and Curls
  • Affiliate Program
© 2007-2012 eSewingWorkshop.com. All Rights Reserved.
