Working with muslin
Fri, 08/31/2012 - 14:41
KT1408
Should I prewash muslin before using on a project? I will be making a dress
Thanks.
Kate
Tue, 09/04/2012 - 15:11
Re: Pre Shrinking Muslin Fabric
 Dear Kate,
If you are using the muslin to do a test of your pattern, you just need to press it with steam. This way after joining the pieces together pressing will not affect the fit of the muslin. However if you plan to wear the muslin, you should be pre shrinking it.
