Caring for your embroidered piece
Thu, 09/08/2011 - 20:40
bjack
I intend to do some embroidery using the stem stitch.  May I know if you use a lightweight interface / stabilizer for the back of the fabric?  Also what are the washing / ironing instructions for a stitched piece?
TIA.
Barbara
Fri, 09/09/2011 - 12:01
Re: Caring for your embroidered piece
Dear Barbara,
This really depends on the fabric you are using and the effect you are looking for. Even if you are using a very fine fabric you may not want to stiffen it.
It is always best to test fusible interfacing or stabilizers on a piece of your fabric first. Try with light weight first and work your way up if needed.
Always preshrink your materials.
To wash your work use gentle detergents and wash by hand or on delicate cycle. If you intend to wash by machine use a lingerie bag to protect the stitching.
Always press from the wrong side.
Fri, 09/09/2011 - 21:03
bjack
Appreciate your advice.  Thank you Nehzat.
Barbara
