checking the upper hip measurement on the block
Mon, 01/04/2010 - 11:56
veronica
in the straight and tapered skirt block pattern making video lessons, chapter11, (checking the upper hip measurement).  i was wondering why is it that the drafted pattern is off, what makes this happen?  i had to add 10mm to my pattern at the upper hip.   veronica
Wed, 01/13/2010 - 16:51
Re: Checking the upper hip measurement
Dear Veronica,
The reason why we need to adjust the upper hip measurement on our block pattern, is that we do not measure and mark it on the upper hipline before drawing the side seam.
We need to measure and mark it after connecting the marks on the waistline and lower hipline.
There is noting wrong with adding 10 mm, as long as you follow the instructions and draft the pattern according to your specific measurements.
Thu, 01/14/2010 - 13:10
veronica
dear nehzat, thanks for
dear nehzat, thanks for explaing this to me. now i see why i was confused, i went back through my steps and noticed that when i connected the waistline to the lower hip i never measured out the upper hip. i over looked that, now it's so obvious. thanks again, veronica
Thu, 01/14/2010 - 13:54
Dear Veronica, Your are
Dear Veronica,
Your are welcome, any time.
