Drafting Plus Size Pants Block Pattern
Wed, 10/05/2011 - 14:46
garmas28
User offline. Last seen 14 years 4 weeks ago. Offline
17 - Drawing the New Front Waistline
Is this the same way to draw a plus size pattern?
Wed, 10/05/2011 - 14:50
  Dear garmas28,   Yes you
Dear garmas28,
Yes you can use the same method. Later you need to check the crotch length on your pattern and compare it with the crotch length on the body and make the adjustments according to the body shape.
Watch the Pants Pattern Alteration (Adjustment) for Different Body Shapes Video Lessons to learn how to make the adjustments.
