Sewing with Jersey, help please.
9 replies [Last post]
Tue, 12/23/2008 - 14:58
fionac65
User offline. Last seen 16 years 39 weeks ago. Offline
Hello,
My name is Fiona and I am new to eSewing. I have learned quite a bit via the videos, thank you.
I am going to make a dress for myself with Jersey material, I have never sewed with Jersey before and I have heard it is not the most friendly fabric to work with unless you have a few tricks.
Should I pre-wash the Jersey fabric.
Can I use just the serger to sew my dress if so which stitich should I use.
I should be getting my serger tomorrow and I am new to using a serger but would love to use it.
What tention would be best for Jersey, should I use 3 or 4 threads?
Should I just use the sewing machine or a combination of both machines?
Is there a certain type of needle I should use?
Also what is the best way to hem Jersey to make it look nice, as it is a dress?
The dress will have long sleeves,any tips for sleeves with Jersey material?
Are there any other tips worth knowing before I begin my project?
So sorry for all the questions, but I am eager to start sewing again as this is a hobby of mine I have not been able to partake in as I have a busy life with work and kids, but I need to start sewing again and be creative.
Thank you in advance for all the help you can give regarding Jersey..I think I am all set to begin once I get all the tips and advice. I am hoping my serger comes tomorrow, I do have my sewing machine as well.
Thank you and best wishes
Fiona
Ontario, Canada
Tue, 01/13/2009 - 00:13
RE: Thread for Jersey
Dear Happy,
Wooly Nylon is the thread. It's suitable for knit and stretchy fabrics.
You can also use regular polyester thread, I haven't experienced any problems when using them with sergers.
For jersey fabric when using a sewing machine another option for straight stitches is to use Wooly Nylon thread for the bobbin and Silk thread for the top (since silk thread has some give).
Sun, 01/11/2009 - 11:51
happylittlemom1
User offline. Last seen 16 years 14 weeks ago. Offline
RE: Sewing with Jersey
Would it be useful to use a special type of thread with jersey material? I have used... I think it is called Wooly Cotton... it is definately wooly 'something'.. and I was told it was for use with stretchier fabrics. Is this just an option and regular thread would be ok? Curious for myself as well since I have little boys who have lots of clothing made of these types of fabrics. Thanks ;-)
~Happy
Wed, 01/28/2009 - 20:42
fionac65
Sewing with Jersey
Dear Happy,
I'm glad you asked this question regarding the thread... and thanks for th answer Nehzat.
Would the two top threads on the serger be polyester and the other threads be the wooly nylon?
Thanks again
Fiona
Sat, 02/07/2009 - 20:38
 Dear Fiona, When using a
 Dear Fiona,
When using a serger you can use the wooly nylon thread for all when sewing with knitted and stretchy fabrics as well.
On a regular sewing machine you can use wooly nylon on the bobbin and silk thread for the top when sewing knitted and stretchy fabrics as well.
Sat, 01/03/2009 - 19:05
Dear Fiona,
I am happy to hear the site has been helpful.
If you are planning to wash your dress at home and your fabric is cotton, you can pre-shrink it. Other wise there is no need to worry.
Take your time and read the manual it is the best source for your particular model.
With regards to the needle – you could use a ballpoint style or a semi-ballpoint universal needle. For the delicate knits use needle size 70 (10). For medium thickness use 80 (12). Size 90 (14) needles are good fabric like polar fleece.
The tension setting depends on the fabric, its thickness and the thread being used. You could practice on a piece of your material to check what tension will work best.
When threading your serger for practice, use different colored threads like indicated on the machine. This will allow you to see if there are any threads that need their tension adjusted. This way you will learn what each thread does and can adjust the tension even when all the threads are the same color.
Yes you could use just the serger, or a combination with a domestic sewing machine. You could use the stretch stitch settings of the domestic sewing machine to sew any darts and do any hemming you need. You could also hem by hand using catch stitches or invisible catch stitches; this will give a finer appearance to your work. For the sleeve and neckline you could do piping from your material – this will make it look nice.
Before attempting to sew your dress, it is good to practice on an old tee shirt. Practice by cutting a few pieces, pinning them together, and sewing a few seams using the stretch stitch settings on your domestic machine if you have them.
Practice with your serger as well, doing seams using 3 and 4 threads, to get familiar with it. Also sew on single, double and triple layers to get the hang of it. Using 3 threads is more economical, while using 4 threads will help secure the stitches better. Serging with 2 threads is good just for seam finishing.
It’s good to cut the jersey with a bit wider seam allowances, since jersey fabric stretches while it is being cut. Before sewing with the serger, baste all the seams and do a fitting to make sure it fits well. If you sew with the serger right away, you will be left with narrow seam allowances, which are impossible to let out.
I hope you found this serging info helpful.
Wed, 01/28/2009 - 20:35
#6
fionac65
Regarding sewing Jersey knit.
I had no idea my question had been answered by so many, how do I set my account so that I am notified of an answer?
Thank you so much for your reply, I have not had a chance to even start my dress yet, I am affriad... but seeing your answer and advice helps me feel a little more confident. I will definately practice on an old t-shirt as you suggest.
Again, I thank you for your help.
Take care
Fiona
Sat, 02/07/2009 - 20:19
#7
Dear Fanny, The feature that
Dear Fanny,
The feature that automatically notifies members when a reply on a form topic has been made is a little buggy and my developers are working on fixing this problem. Once it has been fixed we're going to make a guided tour explaining how the feature works.
Don't worry too much, the more your practice the more confident you will become!
Tue, 12/30/2008 - 02:25
#8
sewgal
User offline. Last seen 2 years 44 weeks ago. Offline
Well Jersey is not that
Well Jersey is not that tricky first it is a knit so you need to use a ball-point sewing needle size 9 or 11. Yes I would pre-wash the material. I don't have a serger I just use a stretch stitch that's built into my machine and light tension also I slightly stretch the material while I'm stitching and always a good hem is a double stitched hem easily done with a twin needle. I hoped I answered some of your questions let me know how it turns out.
Wed, 01/28/2009 - 20:37
#9
fionac65
Jersey Knit
Dear sewgirl,
Thank you so much for your reply, I will let you know how it gos.
I had no idea my question had been answered until now. I have been so busy that this is the first time in ages I have been on this site.
Thanks again
Fiona
