stuck fabric and jammed thread
Sat, 03/10/2012 - 16:23
KarlAndy2012
User offline. Last seen 13 years 40 weeks ago. Offline
hello I am having problems with my stitching I seem to always run into the sitution where the fabic get stuck and doesnt thread jams  from underneath, can anyone help? I keep trying to rethreated it but i keep going back to it and puts me behind on projects, i wanna work simple work but not like this.
Wed, 03/14/2012 - 16:21
User offline. Last seen 3 weeks 4 days ago. Offline
Re: Problem with Stitching
Dear KarlAndy2012,
One suggestion you can try is to make sure you hold the needle thread before you start sewing, at least for the first few stitches. If your thread is jamming, you need to take out the bobbin and re-insert it into the bobbin case again, and top thread again.
Make sure to also insert the bobbin correctly into the bobbin case. Watch the related chapters in the Sewing Machine Essentials Video Lesson.
Let me know now if this helps.
