Little Girls TUTU
Tue, 09/22/2009 - 07:33
adlis
User offline. Last seen 16 years 23 weeks ago. Offline
Hi, I have finally found a terrific sewing site, Thanks.
I am making 4 tutu skirts for my sister's flower girls, would anyone know the best way to sew the waist band as I am using elastic so it can be tightened or let out if need be before the wedding, should I gather the tulle then sew it on to the elastic?  There will be a ribbon sash on the waist line.
If any one can help I would much appreciate it.  Thank you.
Wed, 09/30/2009 - 16:44
Re: Little Girls Tutu
Hi Adlis,
Thanks for your kind words. You can cut a piece of fabric for the waistband with a length which will let it pass trough the hip of the little girls, plus two seam allowances for the ends.
The width should be twice the elastic bands width plus 5 mm and two seam allowances.
1 - Sew the waistband side seam
2 - Gather the top of the skirt and join it to one side of the waistband
3 - Now fold the other side of the waistband and sew it on the gathered fabric to form the casing
4 - Then you can pass the elastic trough the casing by opening a few of the stitches on the inside at the side seam of the casing
5 - Use a safety pin to pass the elastic band trough the casing. If the elastic band is wide, use two safety pins
6 - If you cut the elastic band a bit longer than you need, you can easily adjust it before the wedding
7 - Overlap and use a safety pin to secure the elastic band for the final fitting
8 - Once you do the fitting you can cut the excess length. Leave a 2 cm overlap whipstitch the elastic band at the overlapped edges along the top and bottom using a double threaded. The stitches should be about 3 mm apart.
9 - Then re-sew the side seam of the casing by hand
