looking for adjusting tension on a husqvarna embroidery designer 1
Fri, 03/26/2010 - 13:56
katy121
User offline. Last seen 16 years 10 weeks ago. Offline
ok ladies get your thinking caps on. if any one has knowledge fo a husqvarna embroidery machine help is needed.. going crazy.. the bobbin thread is coming up on top of design.. and of course working on dark fabric so i see white... yeegads.. can some one tell me where and how to adjust upper tension on this machine.. can't find my manuals of how to adjust this.. have to deliver this stuff in the morning.. you can also email me at wildkate@aol.com.. sure would appreciate any help someone can give me.. im on medication and it has my coherant thinking all messed up..
thanks all
Wed, 03/31/2010 - 13:07
sewingbug
Embroidery with Husqvarna
Hi Katy, It seams to me that the problem you are having is with the bobbin thread tension, not the top thread tension. If the bobbin thread tension is lighter, the bobbin thread will poke trough and be visible on the surface of you work.
You should have a slight resistance in the bobbin as the thread is being pulled trough the bobbin case.
You can usually adjust the tension by adjusting a screw on the bobbin case.
