Pattern drafting.
Tue, 08/03/2010 - 11:51
crest2
User offline. Last seen 14 years 33 weeks ago. Offline
Hi Nezhat, I am confused about which skirt pattern drafting video I need to follow. I am only a size 12, but I have a belly because I resently had a pair of very large twins. Which method do I use to take my body measurements? Thanks.
Wed, 08/04/2010 - 11:00
Re: Which Skirt Pattern to Choose
Hi Crest2,
Congratulations for your baby twins. Its good to see that even tough you have two little ones, you continue pursuing your passion.
For any body shape that deviates from the standard body shape we need to use the Full Figure Skirt Block Pattern lesson.
In your case you should also use the Full Figure Lesson, this way the hemline of your skirt will be parallel to the ground all the way around. Also the front part of your skirt won't be pulled up and the back won't be pulled forward when you wear the skirt.
Happy Sewing,
