Welcome!  New visitor? Learn more, click here.  Already a Member? Log in here.
Questions? Call Free 1-888-889-7544 or Internationally +1-647-260-0615
  • Member Log In
  • Home
  • Online Learning ▼
    • Garment Sewing + Alteration
  • DVDs ▼
    • Garment Sewing + Alteration DVDs
    • Tell a Friend (Email Form)
  • Learn More
sleeve pattern not included
Thu, 08/26/2010 - 08:01
tammu
User offline. Last seen 1 year 16 weeks ago. Offline
 Hi nehzat
I made a bodice block pattern for my daughter. When i made the muslin it turned out to be one with a very good fit . Not much adjustments really.
I thought i will make a normal sleeve for it.  I cant find any instructions for sleeves in the library. Will you be posting sleeve making video soon?
Another thing how do i turn a well fitting block pattern into slightly loose top/dress
thanks
diana
Comments
Fri, 08/27/2010 - 11:47
User offline. Last seen 9 hours 18 min ago. Offline
Re: Bodice Block, Sleeve Pattern and Adding Ease
 Hi Diana,
Congrats on making the block pattern for your daughter and getting it right. We will add a sleeve block pattern making lesson soon to our online library.
To give ease to your block pattern you can reduce the intake of the darts after drafting the block pattern. You can also add to the side seams from the top to the bottom, both on the front and the back. You may also add more to the side seam at the waistlines compared to the rest of the side seams. Make sure to add the same amount to the front and back side seams when you do this. Then all you have to do is smooth out the lines.
You can add about 5 mm to the side seams on the front and back, this will give you a total ease of 2 cm from the armpit to the hemline in the side seams. If you think you need more ease you can add more. After adding the ease and drawing the new side seams, you measure, mark and draw the seam allowances. It is best to do another test on muslin, before cutting your fabric.
Email or Share this page:
Quick Links
•  Add Your Photos
Watch on Your Mobile Device
  • when to use interfacing
    sewmama
  • Re: When to use Interfacing for Skirt Slits
  • Re: Hemming Trousers
  • Re: Jacket Shoulder Alteration
  • Re: Love Your Site
  • Affiliate Program
© 2007-2012 eSewingWorkshop.com. All Rights Reserved.
