Welcome! New visitor? Learn more, click here. Already a Member? Log in here.
Comments
i enjoyed the lesson but not to my satisfaction because i could not get the steps in drawing the bodice block parttern to enable me try my hands on. i really need these to practice on ma own in the house. tthank you and keep on with the good work done.
bye.
Hi lizy,
The complete lesson can be accessed by becoming an Subscriber.
If you are a Free Member you can subscribe from the My Account link on the top right side.
Hope this helps you out. Bye.
Hello,
Will you be doing sleeves for bodice video? I am interested in making a jacket and top with sleeves.
Sam
please send me pant sewing traning pattern
Dear Ahmad,
We will be working on a new lesson, on how to sew pants from a pattern, which we will draft ourselves.
This will compliment the fly zipper lesson we just released.
Do you need to add Seam allowance on the drafted block pattern?
Hi Louise,
Yes you need to add seam allowances to the drafted block pattern.
Hi! Nehzat,
Is 'Block pattern' and 'Flat Pattern' the same? Also can your block pattern technique be used for making bodice for pre-teen girls? I need to sew a dress for my daughter for up coming event.
Thanks.
Hi! Nehzat,
Good question Louise. I want to know how much seam allowance and where for both the bodice patterns. Are these allowance measurements same for pre-teen bodice patterns too?
I just finish looking at the videos. It is so thorough, easy to understand and solved many of my mystries. Thank you Nehzat and keep up the great work.
Thanks.
Hi did,
Yes flat and block pattern refer to the same thing. You can use the same bodice block pattern for your daughter as well. The only difference might be that your daughter may not need bust darts because of her figure.
Hi didi,
Thanks for your kind words.
You can add between 1.3 to 1.5 cm for the neckline seam allowance. Between 1.5 to 2 cm for the shoulder line. Between 1.3 to 1.5 for the armhole. 2.5 cm for the side seams and 2 to 2.5 cm for the waistline. These measurements can be applied for your pre-teen daughter as well.
Hello,
I love your videos. Will you ever do one on how to make sleeves?
Thank you
Eye
Dear eyeboyle,
Thanks so much. We will be releasing a video on how to draft a sleeve block pattern very soon.
