Bodice Block Pattern-making - Discussion & Feedback
14 replies [Last post]
Sun, 05/31/2009 - 17:54
Dear Members,
Please use this message board topic to give feedback and discuss the Bodice Block Pattern-making (Video Lessons).
Thanks in advance!
Fri, 01/31/2014 - 19:12
Adesuwa
User offline. Last seen 8 years 16 weeks ago. Offline
Great tutorial
 This was really a great tutorial. Please continue. I will definitely go for a years subscription. I want to lean a lot on standard cloth finishings and pattern making. I love this. Thank you so much.
Mon, 07/18/2011 - 13:34
eyeboyle
User offline. Last seen 14 years 31 weeks ago. Offline
Sleeves
 Hello,
I love your videos. Will you ever do one on how to make sleeves?
Thank you
Eye
Wed, 07/20/2011 - 16:37
Re: How to draft sleeve pattern
Dear eyeboyle,
Thanks so much. We will be releasing a video on how to draft a sleeve block pattern very soon.
Fri, 01/15/2010 - 21:06
louiseheisey
User offline. Last seen 16 years 9 weeks ago. Offline
block pattern
 Do you need to add Seam allowance on the drafted block pattern?
Wed, 03/31/2010 - 14:12
Adding Seam Allowances to Block Pattern
Hi Louise,
Yes you need to add seam allowances to the drafted block pattern.
Wed, 10/13/2010 - 13:04
#6
didi
User offline. Last seen 15 years 6 weeks ago. Offline
How much seam allowance and where all?
Hi! Nehzat,
Good question Louise. I want to know how much seam allowance and where for both the bodice patterns. Are these allowance measurements same for pre-teen bodice patterns too?
I just finish looking at the videos. It is so thorough, easy to understand and solved many of my mystries. Thank you Nehzat and keep up the great work.
Thanks.
Wed, 10/13/2010 - 17:22
#7
Re: How much seam allowance and where
Hi didi,
Thanks for your kind words.
You can add between 1.3 to 1.5 cm for the neckline seam allowance. Between 1.5 to 2 cm for the shoulder line. Between 1.3 to 1.5 for the armhole. 2.5 cm for the side seams and 2 to 2.5 cm for the waistline. These measurements can be applied for your pre-teen daughter as well.
Wed, 10/13/2010 - 13:03
#8
didi
Can block pattern be used 4 pre-teens? what change is needed?
Hi! Nehzat,
Is 'Block pattern' and 'Flat Pattern' the same? Also can your block pattern technique be used for making bodice for pre-teen girls? I need to sew a dress for my daughter for up coming event.
Thanks.
Wed, 10/13/2010 - 17:02
#9
Re: Can Bodice Block Pattern be used for Pre-Teens
Hi did,
Yes flat and block pattern refer to the same thing. You can use the same bodice block pattern for your daughter as well. The only difference might be that your daughter may not need bust darts because of her figure.
Thu, 12/31/2009 - 16:58
#10
Re: Pants sewing from a pattern
Dear Ahmad,
We will be working on a new lesson, on how to sew pants from a pattern, which we will draft ourselves.
This will compliment the fly zipper lesson we just released.
Tue, 12/29/2009 - 12:33
#11
ahmad
User offline. Last seen 16 years 22 weeks ago. Offline
pants sewing training
please send me pant sewing traning pattern
Tue, 08/04/2009 - 20:19
#12
sam50
User offline. Last seen 16 years 26 weeks ago. Offline
Sleeves for bodice
Hello,
Will you be doing sleeves for bodice video?  I am interested in making a jacket and top with sleeves.
Sam
Mon, 06/01/2009 - 06:03
#13
lizy
User offline. Last seen 12 years 39 weeks ago. Offline
bodice block pattern -making
i enjoyed the lesson but not to my satisfaction because i could not get the steps in drawing the bodice block parttern to enable me try my hands on. i really need these to practice on ma own in the house. tthank you and keep on with the good work done.
bye.
Mon, 06/01/2009 - 12:20
#14
sewingbug
Re: Accessing bodice block pattern -making
Hi lizy,
The complete lesson can be accessed by becoming an Subscriber.
If you are a Free Member you can subscribe from the My Account link on the top right side.
Hope this helps you out. Bye.
